Topic: Why are there no analog input options for the RayDAT?
Hi there,
I'm trying to understand why there are no analog input options for the RayDAT...
Why isn't there an "analog breakout cable" available for the RayDAT, or at least something comparable to the AI4S-192 AIO or AO4S-192 AIO that I could use with it?
Will there ever be such an option?
Thanks,
  — Alan
Re: Why are there no analog input options for the RayDAT?
No. If you need multiple ADAT I/Os then the reason is that you connect it to several devices having such a port. In 99% of the cases these have analog ports.
