Topic: How do I record my synths and drum machines on the babyface?
Hello, I just bought the Babyface the other day. I'm a bit puzzled because I've seen the Line in from the device are all XLR, while the outputs from my hardware is mostly 1/4". Is there any problem if I wire from 1/4" to the XLR from the babyface? I'm pretty noob at this stuff but I've been told is not normal practice to do that and I could harm the audio interface.
Thanks.
blizt
Re: How do I record my synths and drum machines on the babyface?
No harm if you just use suitable adapter cables. Any gear outlet or cable supplier will help you..
3 (edited by blizt 2013-04-17 13:01:47)
Hello Daniel.
Is there any difference if I use an adapter like you are telling me,
http://www.lindy.co.uk/lindyshop/pictures/6060big.jpg
to using a cable like this?
http://images.esellerpro.com/2225/I/246/6/medscaleKM6MP2MBLK_3.jpg
I'am going to degrade the audio taking any of those routes?
Thanks.
blizt
No difference, and no degradation....
Ok, thanks for clearing that for me Daniel. I can tell you I'm going to sleep better tonight tongue I just bought both, adapter (from neutrik brand) and cables, just in case. Will try that.
Thanks again.
blizt
