Topic: Installation of 17.3 USB driver fails (OS 10.8.3) - Signature?
Hi
I just tried updating to the latest version of the Fireface USB driver (17.8) and it failed.
My Mac tells me the digital signature has been revoked when I click on the question mark next to a not-informative error message. Can anyone tell me more about this or can RME release a fixed installer?
Gatekeeper is set to "no restrictions".
MacBook Pro Early 2011, 10.8.3, Babyface, previous driver version 17.3
Here's the log of my first attempt. Now the installation package is being rejected right away.
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: @(#)PROGRAM:Install PROJECT:Install-735
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: @(#)PROGRAM:Installer PROJECT:Installer-614
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Hardware: MacBookPro8,2 @ 2.20 GHz (x 8), 8192 MB RAM
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Running OS Build: Mac OS X 10.8.3 (12D78)
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: TMPDIR=/var/folders/vr/l_q3cjtn61nc731g47k2p1_r0000gn/T/
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: SHELL=/bin/bash
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: HOME=/Users/stefan
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: USER=stefan
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: LOGNAME=stefan
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: SSH_AUTH_SOCK=/tmp/launch-JUFpeJ/Listeners
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: Apple_Ubiquity_Message=/tmp/launch-ljqwzL/Apple_Ubiquity_Message
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: Apple_PubSub_Socket_Render=/tmp/launch-iUJtI1/Render
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: COMMAND_MODE=unix2003
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Env: __CF_USER_TEXT_ENCODING=0x1F5:0:3
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Fireface USB Driver Installation Log
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Opened from: /Users/stefan/Downloads/Fireface USB Driver v1.78/Fireface USB.pkg
Apr 18 00:14:24 Stefans-MacBook-Pro.local Installer[412]: Product archive /Users/stefan/Downloads/Fireface USB Driver v1.78/Fireface USB.pkg trustLevel=2
Apr 18 00:14:36 --- last message repeated 1 time ---
Apr 18 00:14:36 Stefans-MacBook-Pro.local Installer[412]: InstallerStatusNotifications plugin loaded
Apr 18 00:14:43 Stefans-MacBook-Pro.local runner[425]: Administrator authorization granted.
Apr 18 00:14:44 Stefans-MacBook-Pro.local Installer[412]: ================================================================================
Apr 18 00:14:44 Stefans-MacBook-Pro.local Installer[412]: User picked Standard Install
Apr 18 00:14:44 Stefans-MacBook-Pro.local Installer[412]: Choices selected for installation:
Apr 18 00:14:44 Stefans-MacBook-Pro.local Installer[412]: Aktualisieren: "Fireface USB Driver"
Apr 18 00:14:44 Stefans-MacBook-Pro.local Installer[412]: Aktualisieren: "rme_usb_install"
Apr 18 00:14:44 Stefans-MacBook-Pro.local Installer[412]: Fireface USB.pkg#rmeusbinstall.pkg : de.rme-audio.firefaceUsbDriver.rme_usb_install.pkg : 177
Apr 18 00:14:44 Stefans-MacBook-Pro.local Installer[412]: It took 0.00 seconds to summarize the package selections.
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: -[IFDInstallController(Private) _buildInstallPlan]: location = file://localhost
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: -[IFDInstallController(Private) _buildInstallPlan]: file://localhost/Users/stefan/Downloads/Fireface%20USB%20Driver%20v1.78/Fireface%20USB.pkg#rmeusbinstall.pkg
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Set authorization level to root for session
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Will use PK session
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Starting installation:
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Configuring volume "OS_X_ML"
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Preparing disk for local booted install.
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Free space on "OS_X_ML": 9.89 GB (9892958208 bytes).
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Create temporary directory "/var/folders/vr/l_q3cjtn61nc731g47k2p1_r0000gn/T//Install.412KQabPs"
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: IFPKInstallElement (1 packages)
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Using authorization level of root for IFPKInstallElement
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Failed install preflight: Error Domain=PKInstallErrorDomain Code=102 "Das Paket „Fireface USB.pkg“ ist nicht vertrauenswürdig." UserInfo=0x7fddbbab2810 {NSUnderlyingError=0x7fddbbac46e0 "Der Vorgang konnte nicht abgeschlossen werden. CSSMERR_TP_CERT_EXPIRED", NSURL=#rmeusbinstall.pkg -- file://localhost/Users/stefan/Downloads/Fireface%20USB%20Driver%20v1.78/Fireface%20USB.pkg, PKInstallPackageIdentifier=de.rme-audio.firefaceUsbDriver.rme_usb_install.pkg, NSLocalizedDescription=Das Paket „Fireface USB.pkg“ ist nicht vertrauenswürdig.}
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Install failed: Die Installation ist aufgrund eines Fehlers fehlgeschlagen. Wenden Sie sich an den Hersteller der Software.
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: IFDInstallController BBA3DD70 state = 7
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: Displaying 'Install Failed' UI.
Apr 18 00:14:45 Stefans-MacBook-Pro.local Installer[412]: 'Install Failed' UI displayed message:'Ein unbekannter Installationsfehler ist aufgetreten.
Die Installation ist aufgrund eines Fehlers fehlgeschlagen. Wenden Sie sich an den Hersteller der Software.'.
Apr 18 00:14:48 Stefans-MacBook-Pro.local Installer[412]: No unstarted install windows: will not relaunch
