Topic: adi -8 ds mkIII
hi, i can't find in tech specs how much is the output impedance of analog out. Can i connect this dac directly to power amplifier?
thanks
Andrea
Re: adi -8 ds mkIII
Hello Andrea,
Specs are in the manual, page 26.
https://archiv.rme-audio.de/download/adi8dsmk3_e.pdf
Line Out 1-8, TRS
• Maximum output level: +21 dBu
• Output: 6.3 mm TRS jack, servo-balanced
• Output impedance: 75 Ohm
• Output level switchable +4.2 dBu, +13 dBu, +19 dBu @ 0 dBFS
Line Out 1-8, D-Sub
• Maximum output level: +27 dBu
• Output: D-sub 25-pin, electronically balanced
• Output impedance: 150 Ohm
• Output level switchable +4.2 dBu, +13 dBu, +19 dBu, +24 dBu @ 0 dBFS
