Topic: Multiple Raydat Cards Cascaded
Is it possible to have multiple Raydat PCIe cards installed and working as one single ASIO driver?
If yes, how many cards will work at the same time?
Thanks!
Re: Multiple Raydat Cards Cascaded
Yes, up to 3 cards. But each has a separate HDSP mixer.
In theory, the driver supports up to 6 cards... cool
How about clock/sync'ing? Does the daisy-chaining work, say for example three Raydat cards?
They can all sync to ADAT input, or if one is master, you can cascade the internal sync connections (cable included in the box).
I have a quick question: If each has a separate HDSP mixer, how about the ASIO driver in the DAW? Do I see all the channels in the DAW of those multiple cards?
p.s. I have HDSP 9632, 9652, and AIO so I can probably test myself, but just wanted to ask before I try.
Yes.
