Topic: Using Sonnet Pro + Hdspexpress card on Thunderbolt
when you use a Sonnet Pro + Hdspexpress card on a Thunderbolt port :
- can you use others peripherals on the same port ?
- is there any thunderbolt hub out there ?
Re: Using Sonnet Pro + Hdspexpress card on Thunderbolt
for the 2nd screen I'm using the display usb adapter by kensington with driver v2.0 (OSX 10.8.3), problem solved
http://www.kensington.com/kensington/en … apter.aspx
