Topic: Totalmix FF800 question about using external hardware/routing....
Hi - I posted this thread on the Reaper forum as well, but I think I may be able to do this within Totalmix
without latency. I'd really appreciate some help with this as I plan to do this with a hardware compressor on master
buss as well.
Thanks!
Ok - so this is the only similar thread I could find -
http://forum.cockos.com/showthread.p...are+compressor
I'm trying to run a stereo mix from Reaper through my preamp and back into Reaper. I'll also need to figure out how to do this with a hardware compressor as that will likely be my next purchase -
So - I ran TRS/XLR male cable from outputs 1,2 of FF800 into XLR inputs of preamp->then ran XLR female/TRS cable from outputs of preamp to inputs 5,6 of FF800. (also tried this from outputs 5,6 of FF)
I then played a stereo mix in reaper and I used reainsert plugin on the track with audio to bring in the audio from inputs 5,6 - I could hear a distinct delay/phasey sound for some reason no matter what I tried. I used the auto detect for reainsert as well. Am I setting this up correctly? Is there a better way to do it without latency? I tried different buffer settings as well. Can I do a send/return on the master track?
I'm also reading up on possibly using Totalmix FF800 software to see if I can route everything there, so if anyone is familiar with that/FF800 that would be great.
I'd really appreciate some help with this. I've been using plugins for this kind of thing for a long time and I'm just getting into using more hardware.
So within Totalmix would I need to use "loopback mode" to solve this?
In addition to the latency, the eq on my preamp also seemed to easily cause feedback, so I'm sure I had something routed wrong in totalmix. There is no issue with my preamp.
