Topic: Strange problem with a second PCMCIA card
I'm going crazy trying to understand why my 4 pin PCMCIA card doesn't work with a MF1 (even with a 12v-12A PSU) but works normally with my DF.
I have another PCMCIA (15 pin) that works with everything.
The problem is the same of other users and posted here in the forum: blinking host error LED, MIDI out activity, TM that recognize another device with spikes on all channels.
Drivers and firmwares are up to date.
Please help
3FRS
Re: Strange problem with a second PCMCIA card
Up to date means what exactly?
Means rev.17 for the 15 pins and rev.55 for the 4 pins.
Rev. 3.35 the driver.
Either the MF or the 4-Pin CardBus seem to be out of spec then. To check this you would have to send both units in.
Germany or here in Italy (midiware)?
I think to ship only the 4 pins card, because the MF works really great with the old card, and because I really need it.
...or you need to test the combo...?
Thank You Mathias
3frs
6
You can try this way, to Midiware.
