Topic: (Mountain) Lion sticky / double FF400 device drivers
I think this started in mountain lion, but it could be lion also I'm not sure.
When I connect/disconnect my FF400, it occasionally happens that my computer thinks it is still connected and shows the driver and the mixer and all. This results in applications hanging that want to stream output to this driver.
When I connect the FF400 again it usually shows up as a 2nd device. So then I have 2 drivers showing FF400 output. I can use the second, but the first one is still there blocking if I use it. Some applications don't let you choose between 2 of the same output drivers so they pick the first one and don't work.
It requires a log out/re-login to get rid of the fantom driver.
Is anyone else experiencing this kind of behavior. I've updated to the latest drivers and firmware.
