Topic: Fireface UC - Mic volume
I recently bought a Fireface UC and when trying to set up the level for my shure sm58 I am encountering problems. The highest value I seem to be getting on Totalmix is about -45 dB. I have tried adjusting gain/level in the settings dialog, but this does not resolve the problem. Also I have tried to change the input level using the rotary encoder on the unit itself.
Any Suggestions ?
Thanks for your time, cheers
DenDon
Re: Fireface UC - Mic volume
Are you using the mic preamp on the front panel? XLR to XLR cable? Have you increased the preamp gain in TotalMix (or using the knob)?
Terribly sorry, but I did not know where to set the pre-amp gain. But I have found it now, thanks very much for the swift reply.
So I can use the following parameters to set my input level, correct ? :
Rotary Knob
Gain/Level Setting
pre-amp gain
Also, what is the difference is between using the Rotary Knob and increasing the preamp gain in Totalmix ?
Btw, my gain settings are +4dBu for line in/lineout/phones.
Best regards
