Topic: On location recording, live-desk, FF800 and phantom power
The support told me that the FF800 wouldn't like incoming phantom power from a live mixing desk too much. How do you guys get your mic signals from a splitter (passive) into the Fireface without blowing it up? Fireface providing the phantom power hoping the FOH desk can handle it?
Any hint appreciated as I have quite a few live recordings coming up.
Thanks,
Peter
MacPro 2009 5.1 (10.13.6, 2x3.46 6-Core), UFX+, FF800, Sequoia 16, Samplitude ProX5, Protools, Logic
2 (edited by fl 2013-05-23 18:00:40)
Re: On location recording, live-desk, FF800 and phantom power
Most professional mic splitters will have a transformer on one of the two splits, which will effectively block phantom power. This should be one of the very first questions discussed when you and the live sound operator first meet. Decide who gets which leg of the split, and therefore who is responsible for supplying phantom power. Then, be professionals and communicate with each other when you are powering up and powering down, so that the other person has a chance to kill their levels. Do all this and look like a pro.
If, on the other hand, you are not using a proper mic splitter, and are just using some sort of "Y" cord, then all bets are off. You'll likely encounter noise issues, possible problems from a voltage drop with the phantom power (can cause issues with Neumann mics), and just general headaches. In this situation, you'd really be better off taking a line level signal from the live sound mixer's effects inserts or from Aux. sends. Of course, then you have to live with the mixer's pre-amps and the levels set by the FOH guy, which may change when you're not looking.
A far better solution would be for you to buy yourself a few single channel mic splitters, like those made by Rolls, and have those in your kit for those occasions when the live sound rig does not have a proper splitter network. While you're at it, buy yourself the same number of short (2 meter) mic wires to run between each mic and each splitter box. Then you can cause less disruption if the live sound person has already placed mics and run lines. Just unplug the mic (after informing FOH and getting permission) and put that wire in one leg of the splitter, plug the short mic wire between the mic and the box, and then plug your own wire into the other splitter leg and presto, you've inserted yourself without generating a huge hassle, other than having to run your own wires.
This way, you're the pro - you have everything you need to make a recording independently of live sound, you're not causing the live sound guy additional headaches, and everybody's happy.
Frank Lockwood
https://LockwoodARS.com
Fireface 800, Firmware 2.77
Drivers: Win10, 3.125; Mac, 3.36
Thanks a lot for the reply, much appreciated! In my case, the gigs are fairly small and therefore there aren't any splitters in their setups, meaning I'd have to provide something. For most live-recordings in the past I used direct outs & AUXes as you suggested but, nowadays, I find a lot of digital desks with not enough analogue outs and only a very few have digital outs that I could connect to my laptop/the Fireface. Therefore, I probably need a splitter with the transformers you mentioned. Anything you can recommend but is affordable?
Thanks,
Peter
4 (edited by fl 2013-05-24 02:29:16)
Ever hear the saying, "buy cheap and you buy twice."?
Like a lot of audio gear, you can spend a little or a lot, but the cheap gear will probably be compromised in some way, and you'll wind up wanting to replace it sooner or later. You might be able to rent a few channels of mic splits from a local PA company or music store before you decide to purchase your own.
Splitters are a pretty simple circuit, so the expense is going to be determined to a large degree by the quality of the transformer. Something with Jensens inside is going to cost more, but you'll probably never regret it once you get over parting with the money. It might be more cost effective to get something that has four or eight channels worth of splits in one box, but I kinda like the flexibility that single and dual channel units provide.
It's probably good idea to learn more about these things - the Whirlwind pages have a lot of good basic information - http://whirlwindusa.com/support/tech-ar … -splitters
An Amazon/eBay/Google search for "mic splitter" will yield a lot of the usual suspects: Radial, Whirlwind, ART, ProCo, Switchcraft, Rolls...
Sorry if this is off-topic for this forum. The location recording forum on Gearslutz is probably more suitable for this discussion.
Frank Lockwood
Thanks a lot. Will have a look and check my options.
Cheers,
Peter
