Topic: Another newbie question on UFX
I am a couple days into my UFX, getting accustomed to total mix fx and I had some questions:
1. Is there a way to split the Main Out 1-2 into two separate outputs rather than a stereo output? The stereo button doesn't seem to toggle the Main Out to mono like the other faders.
2. I am also going to be possibly using this as a 4 channel preamp from time to time. Do I need to slave it to the other interfaces wordclock in this mode if I am using analog outputs, I'm pretty sure I need to for adat/digital outputs.
3. In 4 channel preamp mode, should I send the 4 preamps to 1-4 (i.e. Main out 1-2 or Mic 9 to L Main, Mic 10 to R Main, Mic 11 to An 3 and Mic 12 to An 4) or should I send them to 3-6? I guess it probably doesnt matter and would work both ways.
4. When storing the current state into the device, is this considered setting standalone mode? Therefore, to recall the setup at the display on the front panel, the unit needs to be disconnected from the computer correct? Or is it like recalling a workspace like in total mix?
5. Is there a way to label the stored device states, like 4 chan preamp, live show, practice, etc for easy recall when at the front panel?
Thanks for the help, i did try searching but am new to the forum.
