Topic: Ableton sync with external sequencers
Hi guys,
I was wondering if any of the RME interfaces (UCX, etc) would be helpful in keeping Ableton in tight sync with external grooveboxes and synths that have their own sequencer and timing. I have for example the Elektron Analog 4 and when I send sync from Ableton it noticeably starts to drift after a while from the Ableton timing. I know this is a general issue with Ableton's sync and there are some external clocks devices that can help fix the sync, like this interface from Innerclock systems: http://www.innerclocksystems.com/New%20 … 20Pro.html
The RME cards also have some clock functionalities, but I am not technically competent enough to understand if they will do the same job as this Innerclock thing - sending sample accurate clock to the outboard gear such as the A4.
Your feedback will be much appreciated
Many thanks
