Topic: FIREFACE 800: front instrument input 1 not routing through
just beginning to learn to use my setup so more than likely user error involved here(hopefully). Running my FF800 through Cubase 6. Plugging into input 1 front instrument channel (bass guitar with 1/4 mono jack), LED's light up at that stage, but there's no signal coming through anywhere else i.e. FF input ,output, playback mixer channels, or Cubase mixer.  VST connections are correctly routed. All other FF inputs work including
input 1 through the REAR. Something stupid and simple im overlooking i hope?    thanks
Re: FIREFACE 800: front instrument input 1 not routing through
The setup in the FF800 Settings dialog.
