Topic: second UC with cracklings noise on m macbook pro Need solution pl
hello its my second » RME uc with cracklings noise on outputs in my macbook pro
the first I had, had exactly the same probleme a month ago
so I returned it to the seller !
the second have the same troubles !
cracklings noise
shread noizes
pops
here an exemple of what we can hear every 2 minutes aproximatively
Its on reading only. I have record this with iphone on speakers
https://dl.dropboxusercontent.com/u/862 … %2C23s.mp3
listen at 20s/28s/2,23s
So before you say that there is a problem unit to return, other persons have these problem and in this case the second unit is a new one
so what about a problem with the last macnook pro I7 on mountain lion ?
any idea
Pease I need an answer cause its simply impossible to work with it
Thanks in advance
macbook pro 2012 - mountain lion updated
Logic pro last Version
