1 (edited by zigor 2013-06-03 20:21:09)
Topic: Feeding a cd player output into UFX
I would like to connect a CD player spdif output (cinch) into my UFX. I'm I right if I use a cinch -adat optical fibre link between the player output and one of the adat inputs?
What kind of adapter would you recommend between the 2 units?
Thanks.
Re: Feeding a cd player output into UFX
You can connect to the AES/EBU input, you just need a cable converter for this. See instructions in the UFX manual.
Thanks, Jeff.
I found it in the manual with the cabling description. Much easier than I thought.
