Topic: Calibrating monitors and correct fader level for Totalmix output
When I calibrate my monitors to say K-20 or K-14, what's the default output level to set for the totalmix output faders before I set the monitor gain and test the SPL?
What is the default output fader position in totalmix, to be set, when calibrating the system?
I use the digicheck too, set to whichever K setting I want to use, and I'd love to have some advice on getting this whole process right in terms of setting the right chain.
Kind regards
Re: Calibrating monitors and correct fader level for Totalmix output
+/- 0dB
Ok, thank you very much Dd!  :-)
