Topic: Extended Monitor Control features in Total Mix, please!
Hey Guys,
please give your +1 for the following feature ideas of the monitor control section of Total Mix FX. They should be fairly easy to implement and would make it a professional tool for a great number of rme users. The limitations are acceptable for a small interface, but when you have a madi fx and 196+ channels available, that's frustrating.
- 4 speaker pairs (or more)
- more 'external' sources
- channel swap
- listen to m or s signal only (s phase swapped)
- digicheck pre-master-fader (digicheck should listen to whatever is on the master, but pre-fader.)
Cheers, Klaus
Re: Extended Monitor Control features in Total Mix, please!
+1 for pre fader digicheck.
