Topic: Hammerfall Multiface no audio
Hello!
I'm from Holland, and I'm having a problem with my Multiface I.
I have been using for years RME Hammerfall DSP Multiface as sound card with Cubase 5.
Since last week I suddenly hear nothing. While the card seems to work ok;
I can record tracks using the Multiface (that I can check with M-Audio Ozone, which I use as 2nd soundcard)
Midi I / O works fine of RME
The mixer of the RME itself (if I click on icon next to the clock in the taskbar) just show output. The meters of output go up and down, so there is output signal.
Settings in Cuabse nothing has changed;. Routing just right. And when I try other outputs, instead of 1&2 I useI 3&4 from the RME (and of course also customizable in
Cubase => VST connections) I hear nothing.
If I put my headphones directtly in the RME, I hear nothing.
I'm not technically trained, but I find it very strange.
Does anyone know ...?
regards,
Giel, from the Netherlands
