Topic: Best way to setup outboard?
Hey everyone.
I'm a new UCX user. Love this interface... best on the market IMO. I'm new to RME in general and could use some help.
I have a small amount of outboard processors i'm implementing into my setup. I'm trying to figure out the best way to do this. my DAW is Studio One.
S1 has a vst plugin to incorporate outboard processing. It's pretty simple to setup. However... I notice that when I use it, TotalMix is recording the metronome as well, since it's a "software playback". Is there any way to stop this?
I did some test by not using the vst plugin for outboard and only going through TotalMix, but it's been very confusing for me to figure out the routing. I dont have the hang of it yet. I'm not sure if it will ultimately be easier for me to use S1 or to use TotalMix to do my hardware routing.
Also...which would deliver better quality? This may be a silly question but I am asking for a reason. I did a test where I printed the processing once through the S1 VST hardware device and another by routing through Totalmix. I then tried to null them thinking they would theoretically be the same.. but they completely were not. The VST print seemed to come back too early and had a different sound. The Totalmix print was a little closer to the correct timing.
I'm so confused here. Could use some guidance. It would be really easy for me to use the VST plugin, but i'm worried about quality and also accidently recording the metronome or other system noises into my prints. On the second hand.. its been tough for me getting a handle on how to route in TotalMix. It's a big learning curve. Is it worth it?
