Topic: MMCSS and upcoming Cubase 7.06 update
Hi there,
According to Steinberg, the upcoming Cubase 7.06 (and Nuendo 6.06) updates will have the follow enhancement:
"Improved audio stability
A new "compatibility" switch is now available under Device Setup > Devices > VST. If enabled, the ASIO threads are set to Windows MMCSS mode to improve the overall audio stability."
Since the recent HDSP drivers also have an MMCSS switch, I am wondering what is the most appropriate way to handle this system optimization. Should it be turned on only in Cubase, only in the HDSP driver, or both?
