Topic: RME HDSPe Madi & SSL AlphaLink Madi AX
Hello!
I've been using the above units very succesfully together at 44.1k, but now wish to move to 96k
Master Clock from Swissonic WD8 clocks everything...
Inputs 5&6 on AlphaLink being used for test purposes...
If I select 48K in the HDSP Settings page, I have 64 channels in the Mixer, and signal shows on channels 5&6....correct!
If I select 96k, I have 32 channels in the Mixer [expected], and signal switches to channel 3 - both legs....
THe MADI Input Status reads  64channels/48K frame/48kHz/Optical...this suggests to me that the AlphaLink, while clocked to 96k from the Master clock, is not transmitting this information to the RME...[should the Input status read something like
"32 channels/96k frame/96kHz/Optical"]
On the Alphalink, I have tried Option 2 MADI - 96khz mode - Non SMUX2/SMUX2, and OPtion 7 WordClock out - 96Khz mode,
with no change on the MADI input status on the RME
Anyone any help on changing the options on the ALpha Link t make this happen?
Thank you!
Andy O'Callaghan
1 RME MADI HDSPe & RAYDAT/Nuen5.1/Cub6/WL 7
2 i7 940/9G/RME 9652/VSL1
3 4Cr/4G/MOTU 2408/VSL2
