Topic: DM2000/HDSPe-MADI can‘t sync in sample rate of 96KHz
Hello
I just buy a HDSPe MADI for my new recording studio,By now i have :
1)Mac pro MD770
2)SycroGenius HD-Pro
3)Yamaha DM2000 with Yamaha MY16-MD64
4)HDSPe MADI
I connect HDSPe-MADI to SycroGenius HD-Pro with BNC cable ,make SycroGenius HD-Pro working as word-oclock Master,so HDSPe-MADI and DM2000 become slave.(in additon,AES/EBU expansion card has been installed in DM2000 and connected to SycroGenius HD-Pro ,so the system Word clcock should be star connection. )
We know DM2000 offering multi-channels of 24-bit audio at a sample rate of up to 96 kHz,so I set SycroGenius HD-Pro to 96KHz and lock it,DM2000's dislpay changes to "96K" immediatley, but when I set HDSPe-Madi's "sample rate" to "96KHz " and "Clock source"to"Word clock", it always show "Current:internal" and "Wordclock:No Lock " after trying every option combinations in setting window whether in Windows or MAC OS.
Then I disconnect the SycroGenius HD-Pro, only leave DM2000 and HDSPe-MADI to be master or slave,the 96KHz sync still not available.
Next ,I update the driver to latest V3.07,Update the firmwear to V3.1,it can't reach 96KHz still,also no sounds .But in Sample Rate 48KHz, I found little bit progress that HDSPe gotta proper functioning than before ,In Clock Mode box,"Current" shows"Word clock" and SyncCheck box becomes "Word clock:Sync","MADI:Sync".
So I change system's audio interface back to my echo audiofire8 with SPDIF connection to DM2000 while shutting off SycroGenius HD-Pro,make DM2000 working as word clock Master,Guess what?everything is ok in 24bit/96KHz recording!
what do I miss? Help please.(I have changed another PC to install HDSPe,same things happened. )
