Topic: DIGI9636/52 overides onboard audio
I have a RayDAT system and building a DIGI9636/52 sytem which are being used for Live Mixing (SAC)
In the RayDAT system I use the onboard headphone jack to use media player for 'break music' and feed that into my ad/da converters. works well.
Im assembling a new system with a DIGI9636/52 card. It seems to override the onboard audio and the only recognized audio is the DIGI9636/52. the pc does not recognize  onboard audio in device manager. If I remove the DIGI9636/52 I can use the onboard audio for media player.
I need to be able to use both simultaneously.
Any solutions?
Re: DIGI9636/52 overides onboard audio
The card does not "override" anything, but some boards deactivate onboard audio if another card is present. If there is no BIOS option to keep it active, you will need to add some USB device for system audiio etc.
THANK YOU! Bios was the solution. Once enabled I could re-install driver.
