Topic: OSC feature requests
Hi RME,
please consider adding the following OSC actions:
- sending Pan levels in String format
- sending output levels in String format (I don't mean the Fader levels, but the VU levels)
- adding the OSC action to enable/disable EQ per channel (like the EQ icon in TMFX, which glows yellow when the EQ is on)
- adding the OSC action to control FX-Out and FX-In per channel
- adding the OSC action to control CUE per channel
- sending channel distortion on a seperate OSC action
- sending peak levels on a seperate OSC action
- adding the OSC action to control trim per channel
- adding the OSC action to hide/show elements (like cue or solo), when input is selected send something like /1/solo/1/X/hide 1/0
- seperating the select channel function from the solo function
