Topic: Fireface 400 Input Selector knob does not work any more
I have a Fireface 400, which works well. I usually keep the input selector on "PH" (Phones), and use this knob to adjust the headphone output level. Today I went to select another channel, and discovered that it will not select any other channel any more, it was stuck on the "PH" channel (displaying the volume level). I upgraded the firmware from 1.63 to the latest version, 1.65, and that did not help. I downgraded the firmware back to 1.52, and that did not fix it either, so I upgraded the firmware back to 1.65. This time, the input selector knob was stuck on the channel select function (displaying the channel number), and pressing it will not let me select that channel. I'm stuck, does anyone have a solution?
Thanks, Chris
