Topic: Having trouble Routing my hardware effects through the HDSP E Madi Fx
I'm running cubase 7 on win 7 & using HDspe madi FX with Two aurora 16 (each one is hooked up to it's optical Madi on the RME)
I set up my hardware FX in Cubase connections I.E Tc 3000 Multieffect processor. "Send is using Madi out 75-76 and Return is using Madi in 75-76.
I create my Effect Channel in cubase and assing the Hardware FX insert as the Tc 3000, then i go to my track and assign the send effect to the TC and for testing purposes i put the send level at 0DB.
on the TC i can see the signal is coming in and on my aurora i can see both Signals (the in and the Out). so my routing is setup correctly, but i cannot hear or see the effect level on the return channel and  when i go the total mix window i can my Send level, but my return level is not there (no signal).
any help?
Thank you
chadi Kassem
Mixbox Studio
