Topic: UCX Preset setups in CC mode ?
I'm confused...
Should I put the UCX into CC mode before connecting it to the mac for setting the routing ?
Or should I have the UCX in normal mode, send the Total mix routing to the UCX and change to CC mode for use with the iPad ?
Hope that makes sense ?
Ian
Re: UCX Preset setups in CC mode ?
You can configure input routing on the computer and store in internal memory. 6 slots are available. After storing your preset, you can then switch to CC mode for iPad, and recall the preset.
See pages 94/95 in the manual. https://archiv.rme-audio.de/download/fface_ucx_e.pdf
