Topic: Total mix routing question on a fireface 400
I know this is most probably in the manual that I haven't got and is more than likely quite simple ,but so am I so here we go ;
Im trying to figure out if it's possible to route all 8 of the Adat inputs of a ada8000 into a stereo pair in total mix , is this possible ? So when you open Cubase or Wavelab and select the input of a stereo pair and it will be all of the 8 adat channels , does that make sense ?
The reason I haven't tried routing the fireface yet is because the last time I tried to route something it took nearly a whole day just to put it back exactly how I started :shock: yikes .
What im trying to achieve is having all 4 of my doepfer stereo panners going straight into the ada8000 and basically mixing them to a stereo pair in wavelab to sample .
any enlightenment would be appreciated .
