Topic: controlling Headphone Mixes on several outputs with ADM?
Is it technically possible to control Totalmix with hardware monitoring (in Sequoia), aka ADM on several outputs?
At the moment Totalmix follows my faders in Sequoia if hardware monitoring is enabled for my main output.
Is this possible as well for any given aux bus routed to another output? (My aux send knobs would control the TotalMix faders of this output.)
Or is ADM limited to only one ouptput?
Georg
Re: controlling Headphone Mixes on several outputs with ADM?
ADM (the protocol, and also the implementation in TotalMix) is not limited to one - the host DAW usually is, as it doesn't support the same free independent multiple routing options that TotalMix has.
Thanks for the answer. Is there a DAW that currently supports this?
Georg
Apparently Sequoia/Samplitude can do it. I was not aware of that.
There is some confusion regarding the panning law, though, so that input and playback level can differ up to 9 dB.
But I would seek the mistake not on RME's side.
Georg
