Topic: Extended PCI-E cable for RayDAT
Are there any problem with use this extended cable for RayDAT?
I need move it to other place for search more space.
http://img.dxcdn.com/productimages/sku_155034_2.jpg
Thanks! wink
Re: Extended PCI-E cable for RayDAT
Nobody knows.
Ok but, maybe someone uses this cable (or similar) on other PCI-E cards and could talk about it.
Initially it's only an extension, seems it should work.
You are more than welcome to try and report back... :-)
Doesn't look like this cable would be terribly expensive.
Nice one Daniel, but I still don't have purchased RayDAT. It's a little more expensive that cable. wink
My PCI-E slot's spaceless because big Noctua fan, big graphic card, etc... So I need to use this cable.
I'm afraid I'll have to guinea pig. roll
finally, after a couple of test days, I can inform you that PCIe extended cable works perfectly with RayDAT smile
