Topic: 9652 sync: How to to record 3 preamps with only W/C in on each?
I was trying to record 3 adat-equipped preamps into my 9652, but I couldn't get it to work properly.
I had the RME on internal clock, sending WC to preamp one, T piece to preamp 2, T piece to preamp 3 and then whatever synch worked on the 9652, which was none of them.
Additional background here
http://www.rme-audio.de/forum/viewtopic.php?id=12599
Do I just need to get a W/C distibution unit?
Thanks folks
Re: 9652 sync: How to to record 3 preamps with only W/C in on each?
Some things I can think of:
- Try getting one device to work. Then add the second, and then the third. Troubleshoot one step at a time.
- The last device in the chain needs to be terminated, either by the last device (if it has built-in termination) or by a physical terminator connecting to the open connector on the last T.  If it's built into the last device, don't use a T.
- Make sure no there's no internal termination active in the devices between the clock source and the last device.
- BNC T-pieces and cables can sometimes be faulty; they connect internally mechanically, rather than being soldered. Try pushing the end pieces together.
- Make sure all your devices are compatible to the master clock speed you want to run at, and set to the proper internal settings for them to sync.
I find this WC stuff very fiddly and really good connectors are not easy to find or cheap. I have 4 devices synched this way and sometimes if someone jumps too hard in the CR, the clocks will momentarily go nuts so I've got an issue somewhere...
MBP = HDSPe Expresscard: MF1
