Topic: EQ + Dynamics on monitor-mix/ Recording unaffected/dry signal - HELP!
this might out me as a slight dull, but anyway:
How can  use dynamics and eq on a monitor mix without recording those into my daw ???
Maybe i´m overseeing something obvious here ??
Thanks for your input...
Re: EQ + Dynamics on monitor-mix/ Recording unaffected/dry signal - HELP!
Uncheck "EQ&D for Record" in the settings dialog....
Hi Daniel,
DANKE...!
Another proof for the simple fact that "reading the f... manual helps"!
I´ve been looking only in the total-mix settings for that ... :-)
