Topic: Moving my MultiFace II to a Windows 8 Machine
I've had the Multiface II connected to my Vista machine for about 5 years now.  It's been working beautifully!
Questions:
Will I have to update the firmware once I put the PCI card in the Windows 8 machine?  (I'm asking because I remember the nightmare trying to update the firmware on the Vista machine- could NEVER get it to work and had to remove the PCI card, install in an XP box and THEN update the firmware, take it out, put it back in the Vista box for it to work)
If so, is there an order of the firmware drivers I need to follow?
Can I simply install the CURRENT Windows 8 drivers and be good to go?
Thanks!
Re: Moving my MultiFace II to a Windows 8 Machine
You may need to update, depending on current status... This is not OS dependent, your problems could have been hardware related.
