1 (edited by tajsam 2014-02-07 20:33:52)
Topic: hdsp voltage
will rme hdsp pci card work on 5v pci slot if i use external psu for multiface??
Re: hdsp voltage
What is a '5V PCI slot'?
3 (edited by tajsam 2014-02-08 13:38:06)
Re: hdsp voltage
http://www.startech.com/Cards-Adapters/ … d~PEX1PCI1
this....
i already used old pcmcia card with express card to pcmcia bridge ,and it worked perfect.....
so this bridge will work im sure(uad cards work with this too), but only voltage is my question..
i have to use this because i have 2X hdsp and intel x58 board with only one pci slot...
actually question is, on what voltage rme hdsp card operating??
Re: hdsp voltage
I don't know if this one works or not, but in case there is a problem with voltages your link says simply use the hard drive power connector, so it should work then.
Re: hdsp voltage
thanks.
