1 (edited by Fischfix 2014-02-10 16:14:24)
Topic: Control Surface Programming
i am using a Behringer BFC 2000 Surface to controll the channels for monitor-mixing. This works perfectly however As the controller  has 8 Faders and in my Multiface II i have 14 Channels whenever i press "next" button  the assignment jumps to the next 8 Faders, i jump in the software from input channel 1-8 to channel 9-14 + 1-2 from the Playback row instead of 1-8 from playback to 1-8 from playback to 1-8 from output
so i want in the total mix software only 8 channels or a way to configer the controller is jumping from input to playback to output and always to the beginning of the row.
does someon has a workflow here?
Re: Control Surface Programming
Then not press the next button, but the row down button (top right, up and down).
Awesome! thank you.
