Topic: RayDAT in 96khz - Digicheck Inputs
Hello
When using the Totalyser in 96k (44.1 is fine and works perfectly):
I just can't seem to get any other input than 'ADAT 1+2' working in Digicheck's Input Device Setup.
That took me a while to figure out, as I usually use the AES/EBU 'input' (AES output goes to a benchmark D/A) in loopbackmode for digicheck.
I found out that selecting ADAT 3+4 behaves the same as ADAT 1+2 and from then on 'ADAT 5+6' the display simply freezes, etc .. It also shows all of the available inputs, which might be part of the problem, as they are of course reduced when working in 96k.
The simple levelmeter in hardware mode works (but without the RMS readout), but doesn't in core audio mode, fwiw
Hardwaremode also doesn't seem to work with loopbackmode (which makes sense to me) so i tested this with an spdif out -> spdif in loop.
What am I doing wrong? Thanks!
MacOS 10.6.8, RME Driver 3.07, RayDAT Rev13, Digicheck 0.671
