1 (edited by TabSel 2014-02-21 14:55:53)
Topic: [solved] [Dim] only works on main speakers, not Speaker B?
Bayface, latest release as of now.
control room set up with main assigned to AN1/2, speaker B assigned to PH3/4.
hitting DIM attenuates AN1/2 fader, independant on which "speaker pair" (Main @ AN1/2, or speaker B @ PH3/4) used.
is this desired behaviour?
In my opinion [dim] should work on BOTH speaker pairs, at least on the selected one (which would be the same, as the unselected pair is muted)
Re: [solved] [Dim] only works on main speakers, not Speaker B?
never mind, found it:
http://www.rme-audio.de/forum/viewtopic … 623#p88623
