1 (edited by killcreekaudio 2014-02-25 07:54:26)
Topic: Totalmix crashes upon launch
I have a Madiface XT on a current model quad-core Mac Mini, OSX 10.9, things were fine yesterday using reaper, but as of today Totalmix crashes immediately upon starting.  My suspicion is that Pro Tools has created a problem for it, as I had not used PT until last nite, only reaper.  I have also gone between some displays and have read past reports of that affecting totalmix.  Copied is the error report apple generates when trying to launch totalmix.  Any help would be much appreciated and if there is info I can add to help solve my issue, please let know.  Thanks
EDIT: error report removed for brevity
Re: Totalmix crashes upon launch
Please install the current driver 1.93.
Thank you.  Reinstalling did not help, but manually removing all Madiface driver files as described in the manual followed by a fresh install with 1.93 did the trick.  I think probably PT was causing driver issues for me.  At any rate I successfully tracked 64 channels from my Venue Profile  to a Mac Mini for several hours today without any hiccups, and virtual soundcheck was totally seamless.  The interface is simply amazing.
