Topic: Problem using hdsp Madiface with a MacBookPr Bootcamp Sonnett Echo Pro
I have problems to get following configuration running:
Apple MacBookPro 11,1 (Late 2013)
Bootcamp
latest RME driver
WIN 7
Sonnett Echo Pro
RME HDSPe MadiCard (latest Firmware)
in the device manager I always gat the error code 12 : "Für dieses Gerät sind nicht genügend Ressourcen verfügbar. (Code 12)
Wenn Sie dieses Gerät nutzen möchten, müssen Sie ein anderes Gerät mit Anschluss an den Computer deaktivieren."
Running the device under MacOS 10.9.2 everything is running fine.
I have tested the same configuration using a MacBookPro 10,1 (Eary 2013) the device is running correctly under WIN 7 with Bootcamp.
It seems to be a problem with the MBP 11,1 Bootcamp and WIN 7. Do anyone know a solution?
Re: Problem using hdsp Madiface with a MacBookPr Bootcamp Sonnett Echo Pro
You should ask the Sonnet guys, they really know their stuff.
