Topic: Routing internally on HDSP 9652
Hi folks,
I have an HDSP9652 which breaks out to an ADA8000 from Behringer.  I cannot get into detail right now, but, for argument's sake, let's say I am totally unable to use REWIRE.
I have a DAW, and I have KONTAKT.  Again, for argument's sake, let's say the VST does not function within my DAW.
Thus I MIDI-trigger KONTAKT (the standalone software) from my DAW, and KONTAKT sends its audio out through RME Hammerfall.  Is there a way that I could internally route the audio via RME Hammerfall back into the DAW without having to go through ADDA out to cable and back in via cable through the ADDA conversion process?
Re: Routing internally on HDSP 9652
You could loopback with a adat cable. Just a simple adat out to in on the HDSP.
3 (edited by Scheffkoch 2014-03-07 13:32:30)
...you can internally route via totalmix...e.g. in kontakt you could use out 3-4 and in totalmix you could route out 3-4 directly to in 3-4 and use that as an input in your daw...to do that you have to click strg or alt something like that (i can't remember right now, sorry, but just search the totalmix manual) and then in totalmix the outputchannels you want to route to their input...easy...works like a charm...
Thanks for the tip.
I am just not finding any way to do it, and the manuals/instuctions that I am getting are showing all sorts of routing EXCEPT routing a software out to an "IN".
ANyone have any advice on how exactly to achieve this?
5 (edited by Scheffkoch 2014-03-07 17:55:46)
...ok...i found out it should be "strg" + the output channel to route it inernally to the input...so:
- e.g. you have your daw's out on let's say 1-2
- in kontakt standalone choose e.g. 3-4 as the output channels
- when you play something with kontakt you should see the totalmix meters out 3-4 (3rd row) moving
- click "strg" + out 3 and then "strg" + out 4 (on the label): the colour of "out 3" resp. "out 4" should then turn red
- when you play with kontakt you now should see the meters of out 3+4 and input 3-4 moving
- in your daw select input 3-4 as the input channel
- happy like a house without a roof
...following an old thread this loopback feature is not available for the HDSP9652...sorry...
http://www.rme-audio.de/forum/viewtopic.php?id=3782
Thanks for the trouble.
Bummed that the 9652 doesn't allow this, but...what can one do?
There was a comment about adat cable loopback, but, one cannot, for that will "disconnect" the ada8000 from the 9652, as there is only one in/out, or am i missing something?
A hdsp96/52 has 3 adat in/outs
You could also loopback via the Spdif in/out
Yannick
Hi Vincent,
Quite right, but, I have 3 ADA8000 units, and use all three (24 in - 24 out) in the studio.  :-(
Yannick
This might actually be the way to go!  :-)
You will need something like this :
http://www.camera-espion.com/media/cata … a_male.jpg
Yannick
