Topic: MADI FX AES/EBU re-sampling
If your DAW host is set to 44.1khz and you connect a device that only support 48khz on EAS/EBU is there any way the RME MADI FX card can do a real-time 48khz -> 44.1khz resampling when playback/recording?
RME User Forum → MADI/AES Premium Line → MADI FX AES/EBU re-sampling
On playback: Several programs include real-time sample rate converters. Even WDM and Core Audio can do so. On record I am not sure.
Ok, thanks. Im running sequoia, will check that out.
Sequoia can do so.
