Topic: Problem with window positions in Totalmix under OSX 10.9.2
I recently got a third monitor for my setup and I discovered that Totalmix will not save the window position correctly if I place it on my third screen. I use extended desktop mode with OSX on the middle screen and one additional screen on each side.
if I position Totalmix on the screen to the right of the center screen and save a preset it saves the window position correctly. If I do the same thing on the screen to the left of the center screen the window position gets incorrectly saved on my middle screen.
I'm using a Mac Pro with HDSP RayDat, latest driver version 3.07 and firmware 13.
In other RME software such as Totalmix FX (I also have a Fireface UCX) and Digicheck this works perfectly. Could you look into this?
Thanks!
Re: Problem with window positions in Totalmix under OSX 10.9.2
Is there any chance of fixing this problem? It is causing a problem for me -- everytime I switch between presets my totalmix window jumps to another screen. I have tried the option "Ignore window position" but the behaviour is the same.
Any input would be greatly appreciated.
3
Please download TotalMix 3.071, which includes fixes for this problem, and report back.
https://archiv.rme-audio.de/download/HDSPeMixer3071.zip
The new version of TotalMix v. 3.071 fixed the problem.
Thank you for your help!
5
Released with new signed installer as version 3.08. Thanks for pointing out the problem.
Also good when using a 21:9 screen.
Don't have to resize window if I want to see all 64 channels.
Thank you!
UFX+, FireFace 802 FS, Digiface USB
12 Mic, M1610 pro, Micstasy
MacBookPro M1
Logic Pro X
