Topic: Minor bugs in TMFX 0.999
Global Trim Gain
I've noticed a couple of things since version 0.999
1. Click on an output channel then turn on GTG and then click back on the output channel - GTG does not turn off.  Click on a different output channel and GTG does turn off - which I presume is the designed behavior.  Could we please have an option where GTG is only turned on or off at the GTG button in the Control Strip?
2. Input channel fader groups do not show their colour when GTG is on.
3. Sometimes the GTG button is not lit but all the channel Trim lights are on.
Re: Minor bugs in TMFX 0.999
1. We're thinking about that.
2. That is intentionally as the faders might be assigned to multiple groups. A workaround might be to colour the small triangles matching the fader groups, but I don't know if and when this might be added.
3. That happens when you click on the current active submix output's name field. Same as 1.
Thanks for explaining number 2.  I hope we see a fix for 1 and 3, and maybe a couple of improvements to GTG smile
