Topic: looking for muting output midi messsage
hi,
p. 84 of the latest manual, are given the midi CC of channel volume.
Furthermore all faders of all three rows can be controlled via simple
Control Change
com-
mands. The format for the Control Change commands is:
Bx yy zz
x = MIDI channel
yy = control number
zz = value
The first row in TotalMix is addressed by MIDI
channels 1 up to 4, the middle row by channels 5
up to 8 and the bottom row by channels 9 up to 12.
16 Controller numbers are used: 102 up to 117 (= hex 66 to 75). With these 16 Controllers (=
faders) and 4 MIDI channels each per row, up to
64 faders can be controlled per row (as re-
quired by the HDSPe MADI)
Control Change is very simple thing to achieve.
BUT is there any possibility to midi control the mute button of the outputs ?
thank you
all
