Topic: Multiface won't connect
I just fired up MultiFace for first time in 6 months. Worked great last time. I get a message( FF7-5-000C) that MF will not connect.
the about tab says driver updated 11.30.2007  v3.05.6
Running W XP Pro
Any suggestions on how to correct problem?
Re: Multiface won't connect
So after more attempts I see that MulitFace works fine and the problem is that Nuendo won't connect to MultiFace.
How exactly do you see that Nuendo "won't connect"? Have you considered using an updated driver?
