Topic: SSL Nucleus + AES32 Monitor control
Hi everyone - new to the forum. Apologies if this has been posted elsewhere, I did a few searches and nothing relevant came up so posting a new topic.
I am looking at getting an SSL Nucleus as a DAW controller (mainly). I want to work in surround (film and soundtrack) so I probably won't use the 2 channel DAC's in the Nucleus for anything.
I have an AES32 PCI card on a Windows 7 Pro 64bit machine.
What I want to do (I think) is be able to use a control - fader or monitor controller would be best - to control a group of output faders at once on the AES32 with a single physical controller on the Nucleus, and thereby avoid having to buy a separate monitor controller for the surround set up (5.1).
The AES will feed into a SPDIF converter and run through my now ancient but still perfectly functioning Mobile IO 2882+DSP (yes it's a mac box but it's running as a standalone converter for me at the moment) - which will run analogue to my speakers.
My only concern besides "can it be done and how?" is "will I lose resolution in my mixes if I have to reduce the volume coming out of the AES32 digitally in this way and is it a problem. I mean I know I will lose resolution to a point, but the whole thing is running at 24bits, the question is will it be in any way noticeable or even not noticeable, but somehow an issue.
