1 (edited by ramses 2019-09-02 09:31:40)
Topic: RME Raydat and UFX together in one System ?
I edited my article here, was before maybe not good understandable.
I have an UFX installed via Firewire to my Windows System.
My Near Field Monitors are connected to the UFX.
I would eventuelly love to additionally buy a RME Raydat card for best latencies,
shall I want to play a virtual amp inside of the DAW (VST, etc).
Do you see any way, maybe by special driver, that one could use i.e. UFX and Raydat in parallel in a DAW ?
To be able to make use of both at the same time from Windows (playback) or DAW (actual work via ASIO) ?
So could you mimicry something like a ASIO4ALL, a multiplexer on pure ASIO level, which connects then
as a meta driver to both devices at the same time ? So that both interfaces are useable at the same time ?
Well that would be revolutionary innovative wink
Hope to hear from you if that might be possible and if you regard this idea as cool wink
At the end of the day I would buy a Raydat then on top, maybe others as well wink
