Topic: Globar Record not recording from analogue inputs? - bump
I'm experimenting with RME UCX and DigiCheck 5.72 recording function. I arm for recording both input and playback tracks and display monitoring shows that signals are received from both inputs (analogue inputs and DAW stream) and are monitored as well (level meters show this), but after I do record and try to play back what is recorded it appears that only playback (signal from DAW) channels are recorded and no input (analogue input) is recorded. Also when playing back, same signal recorded from playback channel is monitored both in playback channel strip and input channel strip in corresponding channel, but no expected signal from analogue inputs is available anywhere.
So is there a way to use DigiCheck record functionality to record audio from analogue inputs directly to PC and play it back as it was recorded and how you do this?
