Topic: AES Out on Madiface XT with cable adapter from RME
Maybe I´ve overseen some things, but:
- want to connect the Madiface XT AES Out via the attached cable adapter to an AES IN DAW input from the Crane AvocetII (this connection doesn´t work)
- the AES IN on the attached cable adapter from RME is connected to a Burl B2 ADC (this connection works well so far)
Did I oversee something in the manual or specs?
Thought I could do my A/B monitoring this way instead of using the analogue outputs of the Madiface XT.
André
Mixing Ambulance, Cologne
Re: AES Out on Madiface XT with cable adapter from RME
What exactly doesn't work?
I get no audio signal into the avocet aes-in port.
On the avocet II the port can be configured AES or SPDIF. I´ll checked, it is configured AES. (but also tried with SPDIF)
In the setups for AES Out I didn´t realize any further configuration option for this.
Maybe I´ve understood the connection wrong, but thought, that on the AES Out I can "get" the original signal coming from the DAW into the Madiface.
Anything to do with Totalmix? Loopback or so?
Thanks and best Regards
André
André
The AES output does not do anything on its own... You need to route signal there actively in Totalmix (which you will see in the hardware outputs section) or in your audio software. Only then will something be going to the AES output....
Thanks Daniel,
due to my low manual reading skills, I wasn´t aware of this;-)
I´ll check TotalMix and dive into the "matrix" to get it running…
Cheers
André
André
